Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 04-28-2019, 11:59 AM   #1
truegearhead's Avatar
I like the idea of moving the intake to the trunk and punching a hole through the engine bay. The MAF would have to be right at the throttle body. I wonder if that would require a custom tune.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 04-28-2019, 11:05 PM   #2
Track rat
Topless's Avatar
Drop the weight, it's a physics thing. It will improve acceleration, braking and cornering (faster timed laps). 5-10hp will help acceleration only and you will still get walked by the S2000s on the straights because they have 40hp more, and shorter gears so they put the power down more effectively on long straights. Weight is free and won't require you to punch a hole in your firewall. Drop the weight and get them in the corners.
Another tactic is to run smaller diameter tires to effectively lower your final ratio and shorten your gears.
Old 04-29-2019, 03:32 AM   #3
Ya I hear you. It’s 2300lbs dry with a cage and I’ve added ballast to get to the power to weight limit. Even if I was allowed to loose weight there really isn’t any left to remove. The only thing I really haven’t done is replace the doors with fiberglass.
2003 911 C2
Old 05-07-2019, 07:57 AM   #4
BYprodriver's Avatar
Have exhaust pipes Ceramic coated to retain heat inside.
Old 05-11-2019, 08:28 PM   #5
jaykay's Avatar
......was going to suggest going for some very light weight track wheels. I think this is very often overlooked. Spinning up heavy wheels robs power.
986 00S
