06-17-2017, 04:34 PM
GSR Power Steering Delete Pulley manufacturer?
I am converting to an electric power steering pump (TRW). I have no A/C, so i need a dummy power steering pulley to run my accesory belt.
Unfortunately, GSR is no longer around. My options are to gut the stock power steering pump or fab an 1/2" aluminum plate and mount a 3"/76MM pulley with a sealed bearing that can run with 6PK belt.
It would be great if I could figure out where GSR sourced their pulley. My guess is that it is a plastic Porsche, BMW, Audi, Dayco, or Gates pulley that is compatble with a 6PK belt. I just can't tell with the pics of their pulley on the web where they sourced it from. Does anybody have their kit? There must be some part numbers or identifiers on the pulley that would indicate where they source it from. If I could get this information, it would save me a ton of time trying to locate an alternative pulley.
Thanks in advance for any help.
Pierre
06-18-2017, 07:40 PM
I have a GSR kit that I haven'd installed, so I took a look.
The mount itself is aluminum, has a GSR logo on it and looks to be something they had CNC'd up. It is a simple triangle mount with three mounting bolts. The pulley looks to be an aluminum BMW or Porsche pulley. One bolt center, threads into the mount.
No part numbers anywhere, but would be a simple fab.
06-18-2017, 09:06 PM
MaxD,
Thanks for the info. I have access to a machine shop, so fabbing up the aluminum mount will be easy. Just trying to save some time sourcing a pulley. The pic of the GSR pulley on the web does look like a BMW part. I will continue the search. If i cant find anything, I will just use a gates or dayco pulley.
Pierre
06-22-2017, 03:40 PM
i've a gutted pump that i can weigh if you like. just waiting for the right sized socket to get the valve assembly out. hey, it's free, robust, not that heavy (heavier than an idler puller, however) and you don't need to get a new belt.
06-22-2017, 03:46 PM
I'm running a gutted pump. Not elegant, but works.
06-23-2017, 07:21 PM
Thanks for the info. everybody.
Radium King, if it's not a big deal, can you weigh the gutted pump? If I fab a dummy pulley, I am thinking it will be around 2-3lbs.
bkovac, thanks for the contact info for Michael Essa. I will ping him to see you if he can remember what car he sourced the pulley from.
I have a couple of other projects I have finish up on the M3 before I start on the pulley. I am hoping to get it done sometime in July. I also plan to tackle a custom aluminum mount for the electric pump at the same time. Placing it on the passenger shelf in the frunk instead the floor so I can still use the frunk for transporting stuff.
Pierre
06-23-2017, 07:40 PM
when i got my pump it came with the mounting bracket, and with a bit of bending i was able to make it fit that location quite nicely. i'll try to get you a pic of that as well.
06-23-2017, 08:20 PM
ok, so gutted pump (less the valve - don't have the proper size socket to get that out) weighs 3 lbs without the pulley on. and here's a crap shot of the mounting bracket that came with the pump, bent to fit the frunk ...
06-24-2017, 03:26 AM
What are you all doing about the hydraulic fittings at the rack end? Chopping the old pipes and crimping the end fittings onto some braided hose?
Hergesheimer sell the ends custom turned. Look nice
06-24-2017, 03:33 AM
06-24-2017, 08:53 AM
if you do end up fabricating a pulley, perhaps make a few; appears to be a need. ditto mounting bracket. martsink 3d printed one for floor mounting (like the GSR unit) but no no feedback on how it held up.
06-24-2017, 09:29 AM
I would be interested in a pulley if you decide to make some extra...
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
06-24-2017, 12:54 PM
Did you guys not see the ebay links....they are out there...no need to fab your own
06-24-2017, 01:16 PM
not the pulley but the mounting plate. w an ebay pulley installed w proper alignment, etc. just easier (esp for those w/o immediate access to a machine shop).
06-24-2017, 06:44 PM
Radium King, Thanks again for the info and the pic of the TRW pump bracket.
I'll first tackle the pulley mount. I plan to duplicate the GSR pulley mount. 1/2" Aluminum stock with a 70-76MM plastic pullley. Should be an easy fab - just need to get the alignment right and pick out the right length 6PK belt. If it turns out well, I will make some extra. Just need to finish up some other projects before I can start on this one.
06-25-2017, 06:36 AM
Be very careful drilling in that spot the gas tank is directly under that spot.
06-25-2017, 06:43 AM
Same location with the pump GSR originally sold. In stalled a crimp in nut in the base careful not to drill tank.
06-25-2017, 07:21 AM
