Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 03-22-2017, 10:40 AM   #1
Swiftmotoring's Avatar
MOMO Steering Wheel Airbag Sensor?
For those of you that have replaced your stock steering wheel/airbag with a MOMO non airbag wheel, what is the trick to not tripping the airbag light?
Thx
Swiftmotoring is offline   Reply With Quote
Old 03-22-2017, 10:43 AM   #2
razorsedge's Avatar
You could always just remove the bulb. No more annoying airbag light!
razorsedge is offline   Reply With Quote
Old 03-22-2017, 10:58 AM   #3
Good point!
Old 03-22-2017, 04:30 PM   #4
works bell has a nicely packaged airbag plug kit/male harness. If you google, theres a couple places that has em for about $40. I use this as it came with my wheel.
Other option is resistor. Doesn't look as pretty but gets the job done 2.2ohm 1/4watt
geetee is offline   Reply With Quote
Old 03-22-2017, 04:37 PM   #5
i believe part number is WB-010021 yellow wrapper
Old 03-23-2017, 05:14 AM   #6
I took the airbags out of my doors and passenger side dash. The only airbag I have left is the steering wheel and that's because I haven't bought an aftermarket steering wheel yet. I second the idea of just removing the bulb. It's free and only takes 5 minutes.
Woody
Old 04-03-2017, 05:05 PM   #7
1998 Boxster Owner
If you have a scanner or access to a scanner that turns off airbags...Airbagsystems can make you an airbag shunt. Very easy to install and convenient to pay the extra $$$. Just send them an email with car details and your good. I still haven't figured out how to wire my horn but at least my airbag light is off
Benitom is offline   Reply With Quote
Old 04-03-2017, 11:27 PM   #8
Buy a spare clock spring and use the yellow plug to wire a resistor to, fairly simple to do.
As for the horn you need the 'L' shaped contact from the 993, run a wire from that to the red plug and you'll have a working horn. Total cost in parts was less than £20.
That986 is offline   Reply With Quote
