Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 12-14-2016, 01:04 PM   #1
Need Advice - Tow Hook
I have removed the front bumper of my car and need to install a tow hook for the track. Does anyone have a good recommendation for a Boxster Spec race car? Also, I notice most people use the flat metal loop rather than the nylon strap. Is there a reason for this? Thanks in advance!
JEDD is offline   Reply With Quote
Old 12-15-2016, 11:40 AM   #2
roocox@gmail.com's Avatar
I used a strap, cheap and easy. Also, I can tuck it in so it's not the way. https://goo.gl/photos/tyRH1iCPY4PryTKr7
Minneapolis, MN
'98 Spec Boxster (in-progress build)
'88 924S SP1 (retired)
roocox@gmail.com is offline   Reply With Quote
Old 12-15-2016, 08:31 PM   #3
I always thought that Boxster's (and other race cars with production-style bumper covers) typically used the metal tow hoop to easily place the tow pivot point outside of the bumper cover (to allow the tow truck strap to pivot at various towing angles without contacting or placing stress on the bumper cover itself).
A tow strap that mounts at the bumper mount would create a pivot point inside the bumper cover which may result in the tow strap contacting or placing force on the bumper cover if the tow angle isn't nearly straight.
To avoid this situation with a tow strap, the metal portion of the strap mount is typically extended so it spans the distance from the mounting point to being flush with the bumper cover. If you have to use a metal mount to bring the pivot point flush with or outside the bumper cover, then the strap might be viewed as somewhat redundant.
But at the end of the day, either way can work.
Old 12-16-2016, 09:01 AM   #4
This all makes sense. Thanks very much for the info!
Old 12-17-2016, 11:33 AM   #5
you are correct Tom. The strap type will result in front bumper damage while being towed. I have a retractable on my car, please see link
Rennline Retractable Tow Hook - Porsche-Rennline, Inc.
bkovac is offline   Reply With Quote
