10-02-2015, 12:18 PM
AutoX tips Welcome
I am going to AutoX my '99 for the 2nd time on Sunday! I would welcome any tips for getting the most out of it in slow corners.
I am running 280 TW tires on 17's 225fr /255re.
The 1st outing was my very first AutoX exactly 1 year ago. My car seemed to have alot of understeer, but that could have been me. Since I was beaten by some miatas, I bought a '90 miata like my friends and have done 6 events with it. That engine needs a re-build, so i am back to try the boxster again.
Thanks,
Jeff
1999 Boxster Base Ocean Blue Metallic 85k mi. New to me on 04/2014 w/ 83k mi.
10-02-2015, 12:39 PM
Porsche builds in understeer, its simply safer for unskilled drivers
Tire pressure will effect the under/oversteer.
I am running 32 f / 34 r vs factory 29 f /36 r
225/255 on 17's is much better the the factory 205/255 setup
What tires are you running?
Are you staying street stock, or running a modified class
10-02-2015, 01:41 PM
I am C Street in SCCA, car has not been modified.
Front tires I bought and are Nitto Neo gens,
Rears came on the car and are Maxxis MA-Z1 Victra, which seem to be darn sticky, probably more so than the fronts, but i tried to match the best I could.
10-02-2015, 02:32 PM
with different tires front and rear, it could change the handling a lot
Popular tires for AX in a 986 are the hankook RS-3
10-03-2015, 02:22 PM
Jay, I tried your pressures cold, and it seems to have given me a lot more steering at street speeds. Looks promising for competition tomorrow. Thanks!
10-03-2015, 03:22 PM
What?!?!?!? Crap I just made my number plates... ok B Street doesn't seem fair at all. At least I felt like I had a chance against the FR-S twins
10-03-2015, 03:49 PM
In BS you'll have tons of fun chasing S2000s, Evos, and STIs. I like that it motivates me to continually improve instead of having an easier time beating up the FRS/BRZ crowd in CS.
10-03-2015, 07:51 PM
Cool
Let up know how it worked out
I started thread a few weeks ago that has a formula for calculating tire pressure based on front and back weight and tire width
It gives you good starting point
Weight on front and rear
10-03-2015, 07:52 PM
Originally Posted by rbet
That probably is close to 32F / 34R cold
10-05-2015, 06:21 AM
Thanks for the tips. The car seemed much better especially on corner entry.
I set the pressures to 32 fr / 34 re and when hot they measured 34 fr / 37 re
My first run was a 62 sec and I set my goal at a 58. I ran a 59.9, a 59.0 and then my last run was a 57.9.
That placed me 15/31 , and surprisingly, I was not last place in BS.
Here is a video of my last run:
https://www.youtube.com/watch?v=oueX9lXI834
11-30-2015, 08:37 AM
Thanks again JayG for the tire pressure tips. My car feels so balanced now, I just leave my pressures that way for the street & its much better. Saved me from buying the M030 kit for now.
Jeff
