Old 03-12-2015, 06:43 AM   #1
Ride height?
Hi!
I just wounder which ride hight you use, the same front or rear or?
I know the ride hight have regulations but I just like to know if you use drop or have the same front and rear height?.
Raceroger is offline   Reply With Quote
Old 03-12-2015, 12:57 PM   #2
I'm running 100mm / 130mm but I'd also be interested in what other people are using.
stjoh is offline   Reply With Quote
Old 03-13-2015, 05:11 AM   #3
Good question.
Where are we measuring from? Floor to fender?
What is 100mm/130mm measured from? The floor to undercarriage? so 4" in the front and 5 1/4" rear?
Bigsmoothlee is offline   Reply With Quote
Old 03-13-2015, 08:12 AM   #4
There's a couple of bolts that you measure distance to from the floor. The GT3 shop manual has a description.
Old 03-13-2015, 08:43 AM   #5
Dlirium's Avatar
Great! I'll just go open up my GT3 Shop manual....oh, wait...
Old 03-13-2015, 11:36 AM   #6
The Boxster Spec rules specify the measuring points (I am quoting this since we're in the Racing Section);
Ride height minimum 90 mm front and rear as measured at front cross of aluminum cross member and front-to-rear braces near rear sway bar.
Of course, there are a myriad other ways to measure this.
Old 03-13-2015, 08:47 PM   #7
Topless's Avatar
From personal experience I think 90mm is too low and 100mm is probably pretty close to my current setting. Add in a bit of forward rake and front tire grip improves dramatically.
Old 03-14-2015, 09:58 AM   #8
If you run as high as 130 rear don't you feel the car over steer then?
I run about 95mm both front and rear but don't know if it's optimum?
Old 03-14-2015, 01:37 PM   #9
No significant oversteer but there's of course several other factors that go into that.
Ar du svensk? Var i Sverige?
Old 03-16-2015, 04:56 AM   #10
Japp, Göteborg, Dalmas från början
Old 03-16-2015, 02:06 PM   #11
Ok, från Halmstad men bor i NC.
