Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 06-17-2014, 08:26 AM   #1
rastta's Avatar
New rear window
One of the things I wanted to do after buying the car was replace the rear window on the hardtop. It was cracking in a few places and overall wasn't in too good of shape. It was also not held on as well as I would have liked. Well during one of my sessions the first time I was out - it cracked really bad.
I looked online and found a couple places that made them but they said they couldn't guarantee fitment if it wasn't their hard top. So I had a friend who works for a sign company make me one out of 3/16th's lexan. He also put some black vinyl around the inside edges to trim it out. I did a tracing of the opening and sent it to him and he uploaded it to CAD and then had it CNC cut at his shop.
I fastened it with 5mm stainless button head screws with stainless washers and locknuts. Also used small rubber washers under the washers where they met the lexan. You will notice the extended aluminum pieces on top. The portion of the roof where the top of the lexan sits was very narrow and I didn't want to risk drilling it or the lexan for fear of cracking. The original window was held on by these aluminum pieces (you can see the black rubber plugs in the roof. So I used those to create the three top pieces. There are also small pieces under the lexan which then extend into the inside portion of the roof and act as a clamp to hold the window on. Quite happy with how it came out.
rastta is offline   Reply With Quote
Old 06-17-2014, 08:31 PM   #2
Looks top notch and very professional - great job!
Old 06-17-2014, 09:02 PM   #3
com3dorm3's Avatar
Interesting. I hadn't seen lexan on the oem hardtop.
Did you notice/measure any weight reduction?
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 06-18-2014, 08:07 AM   #4
rastta's Avatar
This is on a fiberglass hardtop - not OEM.
Old 06-18-2014, 02:15 PM   #5
com3dorm3's Avatar
D'oh. Thanks for clarifying.
2000 Boxster S
Old 06-24-2014, 05:40 PM   #6
Sam Mammano
Weight?
Did you weigh before & after ?
2001 Boxster S 986 F Stock
Wellcoached is offline   Reply With Quote
Old 06-25-2014, 08:24 AM   #7
rastta's Avatar
Well - the original "window" was a very thin 1/8th inch piece of plexiglass and it cracked enough that it actually came apart on track. I have a few pieces of it left. I didn't weigh this piece either.
