05-16-2014, 09:07 AM
Sam Mammano
ABS pump wiring harness
Anyone have (or know the part # )for a NON - PSM ABS pump Wire harness .
I am removing the psm abs pump & replacing w NON psm abs pump & need the appropriate wire harness.
My car is 01 Boxster S 6 -speed manual 3.2 - came w PSM
Replacing the PSM ABS pump w NON PSM ABS PUMP- Bosch ABS Brake Pump Part# 996.355.955.06 removed from a 2003 Porsche Boxster 986 Convertible 5 Speed RWD(rear wheel drive) 2.7 VIN# WPOCA29843U621544
Thanks for any help w appropriate wire harness
2001 Boxster S 986 F Stock
05-16-2014, 09:43 AM
The wiring harness is car specific, depending upon how the car was shipped. You will need to get the entire forward harness, which is quite expensive as it covers a lot of the front of the car (Porsche does not break up the harness into a lot of sections). You would probably be better off looking in the junk yard or from someone that converted the car over to a race car.
You are probably also going to encounter CEL/MIL fault codes as the DME is going to be looking for communications from the PSM system and won't see it when you change the harness.
05-16-2014, 10:11 AM
The factory harness for a non PSM 2001 car should be 996-612-951-00, around $120, but I would check that number with a dealer to be sure.
05-16-2014, 10:50 AM
Sam Mammano
Thanks JFP - so do I want to get a new harness for my car (-01 )or do a want a harness for 03 since that is the car the replacement pump is from - or are they the same part #
A quick search of the part # u gave came up with one for $ 66
THANKS!
Porsche Parts - Porsche OEM Parts - Genuine Factory Parts Accessories - Wholesale
05-16-2014, 12:12 PM
This is where I have to say I have no idea as the hydraulic units and harness for 01 and 03 have different part numbers, so the harness may not match the connector. You are also going from ABS 5.3 to ABS 5.7 as well by switching to the 2003 unit, which uses a different control unit and wheel speed sensors (by 2003, most functions were moved over to the CAN bus, so the cars had a different instrument panel that now served as the "hub" for the bus controller network).
05-17-2014, 03:03 AM
Sam Mammano
Maybe I should look for a non abs pump from an 01?
Any differences 2001 2.7 vs 3.2 abs pump?
Thanks for good info.
05-17-2014, 04:15 AM
Can't you go back to where you bought the pump from and ask for the harness ?
I presume it came from a car being parted out
05-17-2014, 04:21 AM
Sam Mammano
tried that - said they didn't have it- wanted to sell me an entire wiring harness $$$$
05-17-2014, 04:49 AM
I can look for a prt number on the harness of my 03 and take you some pictures if that helps any ?
05-17-2014, 04:53 AM
Sam Mammano
Yes, thanks
05-17-2014, 06:20 AM
I'll get on with it strait after work today
06-04-2014, 01:06 PM
Sam Mammano
Factory wiring scematics
Still working on this
As JFP said the wiring harnesses are car specific
My question is - if I supply the two Vin #s , does anyone here have the ability to supply me the two Porsche factorty wiring schematics for the abs pump wiring harnesses.
-one for my current car with PSM vs one from the non PSM abs pump I have to install ) Does that make sense ?
06-04-2014, 03:32 PM
Sorry , I forgot all about this !!!
What do you need ?
06-04-2014, 05:22 PM
Sam Mammano
What do you need ?
Looking for the Porsche wiring schematics for the 2 vehicles
I have both vin # s
06-04-2014, 05:31 PM
If all you need are wiring/flow diagrams , I've come across this before rebuilding a fire damaged 964 many years ago .
The vin was needed to order the right loom from porsche as that showed all the options fitted to that car , but in reality , the schematics where a "cover all bases" affair .
It will be worth getting a copy from Bentley to take a look ,nasty I'd wager its the same schematic for all variables .
Another "promise" , but I have a Bentley here and tommorrow I will take a look !!!
(Busy smoking and drinking corona by the pool at the moment)
06-05-2014, 02:43 AM
Sam Mammano
My email is smammano at Rochester dot rr dot com
06-05-2014, 03:58 AM
Sam Mammano
Do you have the manuals to compare the 2 harnesses?
06-05-2014, 11:45 AM
Sam Mammano
Checking back - any luck w schematics ?
06-05-2014, 12:09 PM
I'm still at work .
Will get onto it as soon as I get home
06-05-2014, 04:05 PM
Email sent .
Let me know if you need any other pages
