Old 05-16-2014, 10:43 AM   #2
JFP in PA
Originally Posted by Wellcoached View Post
Anyone have (or know the part # )for a NON - PSM ABS pump Wire harness .
I am removing the psm abs pump & replacing w NON psm abs pump & need the appropriate wire harness.
My car is 01 Boxster S 6 -speed manual 3.2 - came w PSM
Replacing the PSM ABS pump w NON PSM ABS PUMP- Bosch ABS Brake Pump Part# 996.355.955.06 removed from a 2003 Porsche Boxster 986 Convertible 5 Speed RWD(rear wheel drive) 2.7 VIN# WPOCA29843U621544
Thanks for any help w appropriate wire harness
The wiring harness is car specific, depending upon how the car was shipped. You will need to get the entire forward harness, which is quite expensive as it covers a lot of the front of the car (Porsche does not break up the harness into a lot of sections). You would probably be better off looking in the junk yard or from someone that converted the car over to a race car.
You are probably also going to encounter CEL/MIL fault codes as the DME is going to be looking for communications from the PSM system and won't see it when you change the harness.
