04-03-2014, 05:28 PM
Boxster project??
So this weekend I ended up picking up a 986. Not just any 986 but a pretty serious project. The previous owner has been working on it for many years but the last couple it has just been sitting. I guess he lost interest after some issues with the dealership that did most of the work.
Anyway, now it's mine. So what's different? Well, it has a new (factory remanufactured) 996 3.4 engine / ECU. H&R coil-overs. The brakes come from a later model Porsche, have not figured out which one yet - 997S perhaps. The car is all gutted and bodywork has been changed. Front is fiberglass Cup car, front and rear hood and doors are carbon fiber. Tail section is TechArt (kevlar?) And yeah, it has a full cage. Since the project never got finished the engine, brakes and other mods only have a few miles on them!
It's not a beauty queen but it doesn't need much to become a pretty serious track car.
Since I can't keep both now I have to decide whether to keep it and sell my current street / track 996 or sell it (as is or parted out).
Here's a few pics for your enjoyment. Yes, it needs a serious cleaning, been sitting for awhile.
04-03-2014, 08:07 PM
Jesus Christ.... I wouldn't even allow my cat to take a ride in that car fearing the thing catching fire at launching - in its current state anyway.
FIX IT QUICK
04-04-2014, 05:05 AM
You would consider selling your beautiful 996 for that monstrosity?
04-04-2014, 07:12 AM
Again, it's not a show car, never will be. I don't really care about how it looks, just how it drives.
At just over 2,000lbs, 300hp, great brakes and decent suspension it should be quite a good track car.
Be patient...
04-04-2014, 08:09 AM
Don't get rid of the 996  Try to find a way to keep both
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
04-05-2014, 02:58 PM
looks like potential for a serious track weapon. watch the 3.4 - it's probably even more fragile than the engine it replaced, esp on the track. find eric523 on this forum for a track hardtop for it. kroggers on this forum can provide advice on how to mount the side radiators to work with the rsr side vents. the base car was probably a 986 (hence the need to upgrade the brakes) so it might need the third radiator, and if it is still on the 5-speed then be prepared to replace transmissions on at least an annual basis - smart money is a 987/cayman 6-speed (there's one for sale on rennlist for $4k with LSD). i like it!
04-05-2014, 04:37 PM
Thanks for the suggestions. Having tracked a 996 I'm well aware of the IMS issues with that engine. I'll definitely need at least an X51 oil pan. The radiators are already set up for the side vents. Looks pretty good with a carbon fiber duct feeding them. It does have the third radiator but that one does not have a duct yet. It has the five speed, didn't realize those were so fragile, the 996 gearboxes are pretty much bullet proof. Definitely needs a hardtop so I appreciate the suggestion there.
04-19-2014, 05:59 PM
So I've made a bit of progress over the last few weeks. Nothing earth shattering but I have most of the front done. Fabricated some aluminum brackets for the radiator ducts, got rid of unnecessary ducts, wiring etc. Today I was able to give it a pretty good cleaning to get rid of the cobwebs. Found a lot of interesting stuff, coins, beer bottle caps...
Rear section is next.
04-19-2014, 11:26 PM
What size discs are they....350mm? Are they mounted on gt3 uprights or are the calipers fitted onto stock uprights with some kind of adaptor?
04-20-2014, 07:28 AM
I'm still trying to figure out exactly what brakes I have.
Pads are 996.351.940.10 which per this site are 996 GT3 pads FVD Brombacher Online Shop - 99635194910 - Brake pad gt-3 front 99-02 - BRAKES → Tuning → Brake Pads "Racing"
The uprights are marked 996.341.658.91 which according to this site are GT3 Cup parts Porsche 996 GT3 Cup Radträger - Rennsportteile - MotorsportMarkt.de.
Looks like the discs are about 330mm diameter. I don't have a part number yet.
The calipers are marked 996.352.425 and 996.352.426 (no fourth number).
Based on the above info I guessing that they are GT3 (Cup?) calipers and discs but I don't know. Any help figuring out what the brakes are would be appreciated.
04-20-2014, 12:58 PM
Thanks chap.. you have 996 turbo/997 S/GT3 MK1 type calipers. If 330 then prob disc from same cars...though there was a 5mm difference on the discs across some od those models ....can't remember which.
Your cup uprights make the cost of the whole car much cheaper.....they are valuable!
04-20-2014, 02:00 PM
Thanks for the info. The previous owner threw a lot of money in this project; crate 996 engine, carbon fiber bodywork, GT3/Cup brakes... He said his goal when he started out was to make it a Lambo killer. After awhile he gave up though and bought a Lambo instead LOL.
05-03-2014, 06:10 PM
A bit more progress today. Finished cleaning up the rear trunk area. I was able to get rid of a fair amount of wires back here too. Moving on to the cockpit. After much work I was able to get the HVAC box out. While the wiring looks like a rats nest I did find an actual rats nest behind the passenger airbox cover :-). Also need to remove the hoses for the heater coil and find a way to cap them back at the engine. Removing the parking brake is also on the list.
06-14-2014, 04:59 PM
Wiring done, interior cleaned up and dash installed. Next will be a the seat / harness.
Decided against getting the immobilizer kit, just removed all but the minimum required wires, moved it to a safer locations and installed a push start switch. Should be only a pound or so heavier than removing it.
06-14-2014, 05:01 PM
06-16-2014, 10:55 AM
No.
I have one car we got down to 1950lbs. You are nowhere close (and won't be)
06-17-2014, 07:58 AM
Originally Posted by Brad Roberts
No.
Brad, do you have a build thread? I love to know how you did this.
2003 911 C2
NASA HPDE Instructor
03-08-2015, 01:45 AM
Nice!
Just a simple idea:
03-09-2015, 10:41 AM
Originally Posted by Smallblock454
Nice!
Just a simple idea: ...
It took me a moment to spot the differences. I agree, the hood lines do not make a good break-point for color.
Nice project.
03-09-2015, 10:48 AM
Overall, you deserve huge kudo's for taking someone else's half-baked project and finishing it quite nicely!
Job well done!
