Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 09-01-2013, 05:39 AM   #21
LAP1DOUG's Avatar
Originally Posted by bam914 View Post
The diagram is wrong. The prop valve is on the rear. The next page it tells where each one goes on the ABS unit.
Great find - thanks for sharing. Please let us know how things work out if you replace with an adjustable prop valve.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
Old 09-01-2013, 06:22 AM   #22
Have you considered adjusting bias with different pad compounds f/r?
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
Old 09-01-2013, 06:36 AM   #23
Already did that to start. The main problem is pedal feel. It is too touchy.
Blake Meredith
Flat 6 Innovations Engine Shop Foreman
bam914 is offline   Reply With Quote
Old 09-01-2013, 07:55 AM   #24
You could also reduce the brake booster assist with a vacuum regulator.
Old 09-01-2013, 08:17 AM   #25
Boxster Abuser
Eric523's Avatar
Originally Posted by goldsc_78258 View Post
in the end I would like to run a dual master cylinder set up but for now it works fine.
the dual master set-up really changes the pedal feel. It's hard to drive the boosted brake systems in other cars on track now. Cockpit adjustable knob for bias, and a stand alone BMW M3 ABS unit is optional depending on track surface.
4.0L Dry Sump Boxster GT race car - HRG #23
2005 Cayenne S - DD
Eric523 is offline   Reply With Quote
Old 09-02-2013, 12:00 AM   #26
Eric, are you willing to share details on your set-up for others to do a DIY and reproduce what you have done?
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
Kroggers is offline   Reply With Quote
