Old 02-28-2007, 03:48 PM   #1
987 coolant loss FYI
The Boxster engines penchant for consuming Mobil 1 is well-documented but on both 987s that I've had the car also consumes coolant more than one would think (for a new car).
Both times (987 and 987S), around 12k or so on the clock, I happened to check the coolant level from the trunk and it was significantly below the "min" line at a cold-engine point without triggering the low-coolant light (that the manual says should be triggered) at start-up.
Point being, fellow 987 owners may want to keep their eye on the coolant. The engine oil-low indicator works pretty well, but it seems the low-coolant sensor, not so much.
http://i7.tinypic.com/24ovngk.jpghttp://i7.tinypic.com/24ow0id.jpg
06 987S- Sold
Carrara White / Black / Black/Stone Grey Two-tone
05 987 5-speed - Sold
Midnight Blue Metallic / Metropol Blue / Sand Beige
06 MB SLK350- Lease escapee
Iridium Silver Metallic / Black
We've heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true. - Robert Wilensky
SD987 is offline   Reply With Quote
