02-27-2007, 05:50 AM
scratch on windscreen
Does anyone know what type of product and where can I buy it. I need to try to remove a couple of scratches from my windscreen.
It wasn't a good idea to put my beach chair behind my seat....
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
02-27-2007, 09:06 AM
Go to Google and put in "scratch polish for aircraft windows. It will lead you to the correct place
asenoff
02-27-2007, 09:11 AM
Could probably use that stuff in the infomercial that clear coats over light & deep scratches on sunglasses
02-27-2007, 07:24 PM
I have been using this stuff for scratches on my Harley for a couple of years :
http://www.novuspolish.com/
Use the #3 if it is really bad, and then the #2 to finish up...
( works great on Ipod scratches as well ! )
Hope this helps...
Nick
02-27-2007, 07:58 PM
Nick,
do you have all 3 of those? is it required to use a lot?
i dont really wanna buy all 3 for maybe just a few drops, i have some scratches on both windows and windshield
my cardomain/pictures page
03-01-2007, 07:56 AM
I ordered the Novus kit. It comes w/#1,#2,#3. #1 is a cleaner.
For only 16 bucks...Should be receiving it soon. Can't wait to try it out. I hope it works...
100% de-ambered
painted bumperettes
door sills
Valentine One
03-01-2007, 10:00 AM
Nick -
Have you tried this on the rear plastic window?
03-02-2007, 08:43 AM
djomlas / Travis,
I sent you both a PM but I thought I would share with the group as well...
Novus works great on plastic, but will not work on real glass.
I use Plexus to clean the rear window. I intend to pick up some Renovo for the scratches this year ( thanks for the suggestions, Perfectlap ! )
Nick
03-06-2007, 04:34 PM
Ordered the 3 8oz package off eBay and tried just #1 & #2 on the back window.
 WOW!!
It cleaned the "white fog" that appears along the fold line at each side and in the middle along with some of the scratches.
(Plexus never could get that fog look out)
Will go with #3 followed up by #2 again this weekend for more of a detailed job, but just wanted to say thanks Nick for the link.
Hope this helps...
Nick
03-07-2007, 09:42 AM
Would this also work to remove scratches on the plastic bumper?
03-07-2007, 10:11 AM
My thought would be no for the following reasons:
1. The bumper is not plastic but polyurethane or fiberglass mix if aftermarket
2. Your bumper is painted and followed up with clear-coat
But hey it might work since it is a mild abrasive cleaner, but I would think you would want to use a polish or rubbing compound designed for clear-coat and try to buff it out.
just my .02, not an expert on the matter by far
Here is a link that may be of help.
http://www.paintcare-n-detailing.com/
03-07-2007, 08:23 PM
 WOW!!
Travis,
Awesome ! I was scared to try the Novus on my back plastic window ( I have the "white fog" as well ) - looks like I will put my order for Renovo on hold and give the Novus a shot come spring. Thanks for being the guinea pig on this one !
I have used Novus on the trunk of my car ( I had some minor scratches from taking the speed humps off ) and it worked great. Not sure of the bumper, though, since I am pretty sure it is made out of a different material ?
Nick
03-07-2007, 09:24 PM
djomlas / Travis,
Nick
How do you like the Plexus for your rear window? I've heard this stuff is the best from many sources. I tried it, and i got decent results, but its not as clear as I'd like. Perhaps I'm going about the application/removal wrong. How were your results and how did you apply/remove?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
03-07-2007, 10:45 PM
How's this for oddness:
There is a HAIR... INSIDE my windscreen!! Yes... it's not stuck to the inside, or the outside... it's IN the glass! Given it's a laminate, someone lost a strand. It's about 1.5" long, in the top driver's side position... probably light brown...
If I bought the car new, I probably would have had them replace the glass... just because it annoys me sometime... hehehe
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
03-08-2007, 07:42 AM
chaudanova,
I have been using the Plexus for cleaning the rear plastic window for some time now. It seems to do a good job, and leaves the plastic very soft and pliable. It doesn't seem to help much with the clouding, though, that is what I might try the Renovo or the Novus.
I spray the Plexus on a soft white cotton towel, clean the window, then I use another towel to remove the residue.
Hope this helps...
Nick
03-08-2007, 08:10 AM
That is crazy odd! are you sure its not a deep scratch with brown dirt collected in it. Do you see a root?
