Old 02-23-2007, 02:38 PM   #17
Originally Posted by AFRay007
Thanks for all the responses so far, its been helpful.
Do you guys know how hard consistent -30 type weather is on the internals of Boxster? Will I start to encounter serious maintenance issues?
I'm leaning towards keep her right now and trying weather it out most of the year. Right now financially its not feasible for me to get a cheap beater and worry about maintenance and unreliability of a second car.
I would also much rather drive the Boxster if I can winterize her up.
Thanks again
Oh yeah and Schnell.... youre right, it could be worse. I was at Eielson for a month two summers ago, that place is terrible. At least Grand Forks is a semi university town, UND is 15,000 students and in the middle of the town.
If you can't do the cheap beater avenue than consider the following:
1) Winter tires
2) Hard top
3) Replace serpentine belt right before the cold season starts
4) Make sure you are using the proper weight of oil
5) You might want to consider a more frequent tranny fluid oil change than normal
6) Oil warmer that you plug into an outlet with an extension cord
7) Make sure your coolant is up to snuff for extreme cold weather
Sammy is offline   Reply With Quote
