Old 02-17-2007, 09:10 AM   #1
Undercoating a good idea?
NOVA/DC area, salt and other corrosive chemicals.
Should I get my car undercoated?
BobMarley1 is offline   Reply With Quote
Old 02-17-2007, 10:22 AM   #2
Ronzi's Avatar
Just a personal opinion, but I would say no. The anti-corrosion coatings on body panels today are so much better than they were years ago that I think you have to live in a climate were you have salt on the roads 6 mos. of the year before undercoating is justified.
Ronzi is offline   Reply With Quote
Old 02-17-2007, 10:39 AM   #3
not only for body panels
I'd say it's more a question of choosing the right material.
I agree that present-day body panels are far superior to those of years ago, but a good oiling won't hurt AND it does wonders for undercarriage component, suspension parts, brake lines, fuel lines, all nuts and bolts in general.
Go for it!
wanna986 is offline   Reply With Quote
Old 02-17-2007, 11:05 AM   #4
Ronzi's Avatar
Could be.
When I think of "undercoating" I think of the tar stuff they used to spray underneath, which weighed a ton, and hardened like cement. I suppose the WaxOyl-type coatings are less objectionable.
Old 02-17-2007, 11:24 AM   #5
Send a message via MSN to Darkhamr
Originally Posted by Ronzi
Could be.
Agreed. Undercoating is the black permanent stuff and rust-proofing is the oil spray that needs to be done every two years.
Darkhamr is offline   Reply With Quote
Old 02-17-2007, 11:39 AM   #6
If it's any kind of "goop" we're talking about, I'd definitely advise against it. I believe the dealers usually sell this for its sound-deadening properties. It won't be the best choice against corrosion because a breach in the surface will actually trap moisture- only to begin the process. I speak from expereince, unfortunately.
Old 02-17-2007, 11:46 AM   #7
Not to hijack the post, but, hamr, did you end up getting your car?
