Old 02-04-2007, 02:22 PM   #1
Porscheectomy
Originally Posted by wanna986
Is it normal for the power steering to moan and groan when turning the wheel?
It took a 5 mile trip before it was only audible on extreme turns only. Before that, any slight movement would make me cringe.
What's going on? 2002 S
It's usually a sign that the power steering pump is on it's way out if the level is correct.
Old 02-04-2007, 04:12 PM   #2
BTW wanna986, what year is your car? And do you track your car?
dcporsche99 is offline   Reply With Quote
Old 02-04-2007, 06:54 PM   #3
husker boxster's Avatar
The pwr strg res is in the front left center of the engine and easily accessible when the engine cover is off. Pentosin is a synthetic fluid, so DO NOT put regular pwr strg fluid in it. I was able to find some Pentosin at O'Reilly's. Pentosin is not cheap - $25/qt (what fluid is cheap in a Porsche?). I'm sure you will get varied opinions on whether it is safe to mix other brands of synthetics with the orig Pentosin. My 01 seems to thirst for a little fluid about once a yr, so chances are you are also low on fluid. I would either park it and wait for warmer weather or check / fill it now if you plan continuing to drive it. It cannot be good to run it when it is low.
1989 928 S4 5 spd - black
Old 02-04-2007, 07:58 PM   #4
The power steering is a sealed system. Which makes me ask what would cause it to go low other than a leak?
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 02-04-2007, 08:47 PM   #5
You read my mind, Adam.
In my case, as far as I know, there is no leak. We'll see...
DC- car's a 2002. No tracking.
wanna986 is offline   Reply With Quote
