Old 01-29-2007, 01:49 PM   #1
Send a message via MSN to CJ_Boxster
Well I decided to just replace the 1 sensor and see if the idle and operation of the boxster imporved... which it did greatly! So i plan on replacing the remaining 3 sensors probably sometime between tomorrow and 2 weeks from tomorrow.
I think im lucky cause i still havent gotten an CEL for the other 3 sensors, i hear about alot of people getting CEL for the other 3 when replacing just 1.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 01-29-2007, 08:41 PM   #2
I had always heard of this called an "Italian tuneup," because the old Italian cars would literally need it to run properly... Of course, in my other world of rotary powered engines, the cars that were driven by old ladies to church are known to die of boredom, i.e., the engines build up carbon and it starts to tear at the apex seals...
So keep those revs up, kiddies
Wonko The Sane is offline   Reply With Quote
Old 01-30-2007, 07:07 AM   #3
Brucelee's Avatar
Modern cars generally do not "carbon up" anymore.
However, I would suggest some Chevron FI cleaner. It def. cleans up my funky idle.
Rich Belloff
Old 01-30-2007, 07:26 AM   #4
Hi,
Agree. With OBDII the AF/Timing is so dynamic that it's virtually impossible to Carbon-Up. If you do, you have waay bigger problems than just having the car sitting idle.
On the other hand, as you mention, fuel and fuel quality, have a much greater effect on the performance of a modern engine. Gasoline is a very unstable compound and wants to breakdown into it's constituent parts, some of which are parafins (erroneously referred to as Varnish).
Gas used to be stable for only 30-45 days from refining (not when you fill-up) before it started to breakdown. Modern Gas will go about 60 days before suffering the same effects. This is why a fuel injector cleaner once annually and/or the use of a stabilizer if driving infrequently or storing the car (even for a short duration) is especially helpful...
Happy Motoring!... Jim'99
Old 01-30-2007, 07:36 AM   #5
Hmm, i didnt know that gas has about a 60 day shelf life before it starts to really separate. Ill keep that in mind if i ever store a car.
Carlos J Cazares
Old 01-30-2007, 08:17 AM   #6
Don't they call that an 'Italian Tune-Up'?
Sometimes you gotta feed some speed to your ride!
And the Chevron stuff is 'Techron'. It's about $5-6 a bottle, but works great at cleaning up the fuel system. Used it in my 911 to clean out the fuel lines after transplanting my engine and gas tank into the tub that had been sitting for 17 years.
I usually use a bottle of Techron every time I change the oil, but I think since the Boxster's change interval is a little longer, I'll try to drop a bottle in every 3 to 4k miles.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
Old 01-30-2007, 12:43 PM   #7
Hi,
Lots of people praise Techron, but I've never used it. I use http://www.********************************************/acatalog/Lubro_Moly_Jectron_Fuel_Injection_Cleaner.html developed specifically for Fuel systems in German Cars. This is a well respected Fuel System cleaner and I've always had great results with it. For the Boxster, I use it half-strength, so it's maybe slightly cheaper than the Techron. But, I'm sure they're both good products...
