Old 03-15-2007, 12:00 PM   #1
Send a message via AIM to djomlas
rear flaps...wow
i noticed that one of them was sitting a little uneven, so i unscrewed it and saw some dirt, i said to myself let me just clean it up inside there, expecting like maybe a little rock and few grains of dirt cought, but check out how much came out...just out of that one side
phew, this will save me some time on the track, real weight reduction
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 03-15-2007, 12:04 PM   #2
Send a message via MSN to CJ_Boxster
have you removed the transmission debris sheild, usually theres lots of debris stuck there from past oil leaks. also on the most rear plastic cover under the car., Have you looked where your battery is... should be a good half a pound of leafs in there.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 03-15-2007, 12:18 PM   #3
when i was flushing the coolant i took all the protective covers off the car and a lot of stuff came out, but somehow i never got to this little part, it looks so small, hard to believe that so much stuft can fit in there lol
and yes, there was a lot of leaves in the battery area, cleaned that as well good call
Old 03-15-2007, 12:44 PM   #4
When I put my side skirts on, I had a ton of crap fall from the mud guards too. At least I dont need those mud-gathering things anymore!
2003 Boxster Seal Gray/Gray
TIP
5000 miles (for some reason I'm proud of this)
porschegeorg is offline   Reply With Quote
Old 03-15-2007, 12:53 PM   #5
I'm gonna have to take a look under there when I get her out of storage... might as well give her a thurough spring cleaning!
http://farm1.static.flickr.com/211/4...7e5359a2_o.gif
Owned: 11 months
Miles: 78,000
Autocrosses: 22
Track Days: 1
http://www.crife.net
986 Girl is offline   Reply With Quote
Old 03-15-2007, 01:32 PM   #6
I have a 914, too, and part of maintenance on that car is removing the rocker panels every few months and dumping out the piles of debris thrown up from the wheels. Didn't know I'd picked up a similar task when I got my Boxster. A wet mixture of the kind of debris shown in the picture in this thread is how rust gets started.
pbanders is offline   Reply With Quote
Old 03-15-2007, 03:43 PM   #7
Exactly... now imagine if part of what got stuck up in there was salt too... festering away for even a week at a time is not good for the vehicle.
Owned: 11 months
Miles: 78,000
Autocrosses: 22
Track Days: 1
Old 03-15-2007, 04:15 PM   #8
Don't forget up front in the air intakes for the radiators. Rocks, leaves and various road debris gets in there and can partially block radiators.
-Ray H.
2000 986
1979 911SC coupe
Raybox is offline   Reply With Quote
Old 03-15-2007, 04:53 PM   #9
+1 on cleaning the front radiators. I used a shop vac with the long plastic extension and it worked great. Filled the shop vac about 6" deep with leaves from the previous owner...
Not a lot of weight but good for cooling, etc.
Jeff
jwilson95 is offline   Reply With Quote
