Old 05-23-2026, 04:43 PM   #1
Engine shut down
I have a 2001 3.2 L. I'm on a road trip right now. I could feel that the car was not accelerating. Eventually the engine just shut down and I was able to pull over to side of road. I attempted to restart engine 2 times and it would immediately stop. The engine now will not restart at all but cranks over. I have codes with my simple Elm code reader of P 1126,P1132,P1125 and P1133. I'll be towing the vehicle home. What are the most likely repairs that need to be done?
hookoo3 is online now   Reply With Quote
Old 05-24-2026, 05:40 AM   #2
Air, fuel, spark.
All there?
Sounds like a fuel issue, but you need to diagnose.
-H. L. Mencken
Old 05-24-2026, 04:08 PM   #3
Codes P1125, P1126, P1132, and P1133 indicate that the engine control module (DME) in your Porsche 986 is at its enrichment limit, meaning it is detecting an excessively lean fuel-air mixture across both cylinder banks.
If the MAF sensor sends a corrupted or incorrect reading, the DME cannot properly calculate the air coming into the engine. You can try cleaning it with CRC Mass Air Flow Sensor Cleaner. If the problem persists, the MAF will need to be replaced with an exact Bosch equivalent.
Any unmetered air slipping into the system after the MAF sensor will cause the computer to register a lean condition. Check the rubber intake boots, the resonance tube flapper, and the oil filler tube/cap for cracks or loose clamps. A mechanic can perform a smoke test to locate these leaks precisely.
A torn diaphragm in the AOS can introduce excess unmetered air into the intake manifold. Fuel Delivery System: If the engine is starved for fuel, it will read lean. Check for a failing fuel pump, low fuel pressure at the rail, or a severely clogged fuel filter.
1998 Boxster
2000 Boxster S
2006 Cayman S
1998 911 Carrera
Liam986 is offline   Reply With Quote
Old 05-24-2026, 06:04 PM   #4
I'll first start with the MAF, even tough it probably only has 10K km on it. I'll also check for air and vacuum leaks. Ai indicates that the main cause is probably the AOS. I'll replace it. The fuel system may also be a cause so I will do a pressure test and check the fuel pump and fuel filter. A smoke test is also on the list.Thanks for the suggestions.
Hookoo3
2001 Boxster S
Old 05-25-2026, 08:52 PM   #5
Parts Cannon Operator
boxwrench's Avatar
I had an adventure with P1126 and p1133 last summer.
Fuel pressure is an easy test with a gauge. Screw it into the test port, turn the car on, etc.
You can look at fuel trims in Durametric. RKAT numbers are idle, often affected by vacuum leaks, purge valve, aos, etc. FRA is load/cruising trim, which is less affected by small vacuum leaks and more by fuel delivery issues (fuel pump, regulator, filter).
You can also see MAF numbers in durametric. You can also try just disconnecting the Maf and see if the car will run.
In my case it was a dying fuel pump, but a clogged filter or failing pressure regulator can do havoc as well.
Good luck.
2002 Boxster S - 3.2L manual - Arctic Silver - 143k miles
boxwrench is online now   Reply With Quote
Old 05-26-2026, 02:14 AM   #6
Registered Member
I believe that the 01 has a replaceable fuel filter. If your pressure is zero, or close to it…
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
