Old 03-25-2018, 04:40 PM   #1
I added the 987 rear speaker with subwoofer to my 2000 Boxster S
Fairly easy setup. Run power, RCA cable, speaker wires, and amp turn on signal to the area.
Much improved sound over just the front speakers.
lskolnick is offline   Reply With Quote
Old 03-25-2018, 04:54 PM   #2
The Radium King's Avatar
interesting - it fits with the 986 rollbar ok?
Old 03-25-2018, 07:09 PM   #3
It fits just like the 986 version, and secures to the rear deck the same way.
Old 03-25-2018, 07:51 PM   #4
cool. any idea what the quality/volume would be if you just ran with the rear unit and no door or dash speakers?
Old 03-26-2018, 12:06 AM   #5
Does this only work for 986:es with the BOSE (MOST) sound packages?
square-root is offline   Reply With Quote
Old 03-26-2018, 01:32 AM   #6
It could work for any 986. I don't have Bose.
Old 03-26-2018, 05:31 AM   #7
Do you happen to have the part number?
Old 03-26-2018, 06:42 AM   #8
Has this unit an integrated amp?
If yes, how will get the MOST bus signal to the amp?
Old 03-26-2018, 07:32 AM   #9
I know where 2 are at $187.50 ea.
azlvr is offline   Reply With Quote
Old 03-26-2018, 09:32 AM   #10
i have the stereo gutted out of my car (weight reduction you know!) but it would be cool if i could stuff a small bluetooth amp into the rear speaker unit, run some switched power back to it, and drive it from my iphone - a stereo system that i could pull out of the car when at the track. not sure i would get enough usable volume out of it, however.
and, i have the 987 engine cover, so was uncertain whether to use the 986 or 987 rear speaker unit, as didn't know if they would fit with the cover/roll bar; good info to know.
Old 03-26-2018, 09:47 AM   #11
I looked at ripping out the MOST system and all the associated stuff. In the end I bought a Bose Mini Soundlink II. Cheaper than a head unit. No wiring, 10 hrs battery and sounds great. Also goes into the garden, work and anywhere else.
Sent from my iPhone using Tapatalk Pro
Traco
_________________
Older but no wiser.
2003 Boxster S, Seal Grey
Traco is offline   Reply With Quote
Old 03-26-2018, 10:44 AM   #12
Ciao's Avatar
I use this same system; works great!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 03-26-2018, 12:13 PM   #13
crazy - i have two of those at home. loud enough for cruising around?
Old 03-26-2018, 02:38 PM   #14
Perfect for cruising. If going for a proper burn I prefer the flat six sound track screaming to the redline so it gets thrown in the glovebox then.
Traco
_________________
Older but no wiser.
Old 04-09-2018, 07:13 PM   #15
Cool. Please send me some info. Thanks.
ray_pilot is offline   Reply With Quote
Old 04-10-2018, 09:31 AM   #16
Cunningr's Avatar
I had one of those, got stolen by one of my sons jackass friends. . Couldnt proove which one, stole set of headphones also.
I just dont like loose things sitting around driving normal and an emergency stop things go flying.
Old 04-10-2018, 02:14 PM   #17
DarkStar's Avatar
OP, That is seriously too cool. Looks a ton better than the factory bose!
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
Old 04-10-2018, 07:01 PM   #18
I contacted pdwight about making a harness to make this mod plug and play. He didn't think too many would be interested. Let him know if you are.
Old 04-10-2018, 07:52 PM   #19
DarkStar's Avatar
Oh I'm not, I would be if I didn't have a crazy system for my car. But it is pretty awesome.
-Josh
Old 04-25-2019, 06:04 AM   #20
Hi,
Just read your post on addiing the Bose sub shelf to the system. I just purchased one my self and would like to hook it up to a aftermarket Clarion head unit in my 987 Boxster.
Would you be able to explain me the meaning of the wires ( colour codes ) which are connected to the subwofer build in AMP. Ihave
Would be much appreciated.
Thx in advance.
Thomas
tfeih is offline   Reply With Quote
