Old 06-30-2025, 08:54 AM   #1
Another window drop thread...
My specific situation is this:
Passenger side window drops the required amount to clear the convertible top when the inside or outside door handles are pulled. However the second you let go of the door handle the window pops back up instantly.
So the only way you can close the passenger door after exiting the car is to shut the door while keeping the exterior handle pulled open.
I tried the ziptie trick for the regulator but this seems to be something different. I noticed that if I play with the door lock latch when the door is open, I can sometimes get the window to drop and stay dropped - not sure if that info is helpful here.
Thanks in advance for any help, I couldn't find any threads with this specific scenario.
BoxsterInTheSun is offline   Reply With Quote
