Old 07-01-2025, 03:18 AM   #5
tcoradeschi
Registered Member
Originally Posted by maxbottomtime View Post
If it doesn't drop at all, that's the handle micro switches. The handles tell it to lower the window, and when the door is closed, the latch micro switch tells it to raise the window back up.
OP - your issue is the door latch. More than likely, there is a surface the switch rides on that has a coating/plastic surface that wears.
Exactly the issue at play here. I spent several months trying to fix the issue before I gave up. Fortunately for my, the cheap latch was the necessary solution. Now, why the passenger side latch was the one that failed (the car is primarily driven with just the driver in it), is a bit of a mystery…
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
