Old 06-14-2025, 09:17 AM   #1
Anyone with a 2002 986 that can try something for me?
With the car running, and the front fog lights on ( no other headlights on, just the front fog lights ), activate the turn signal.
Does it switch the fog light on and off as the turn signal flashes?
Trying to figure out if this is expected behavior or a wiring issue.
Thank you!
BoxsterInTheSun is offline   Reply With Quote
Old 06-15-2025, 08:03 AM   #2
Is NOT expected behavior w factory OEM wiring.
Likely one of 3 things in my opinion:
  • intentional (to emulate some late model vehicle signal illumination behavior)
  • bulb related if LEDs installed. these vehicles are pre-LED and electrical system is sensitive to having LED installed w/o proper modifications including resistors etc.
  • 'issue' w wiring harness (getting a short someplace - look for cracked/melted insulation on wires in harness but if same behavior both sides seems more intentional or bulb related)
Start by pulling headlight pod. Check bulbs if LED. If not, then release harness from bracket behind and look for added jumper wire(s) there - most likely a ground. Also check for hacked ground from corner lights (may be improperly hooked to fog instead of signal light (to alternate when flashing - common mod). It does NOT sound like this vehicle had the relay hacked (i.e. a workaround to enable DRL's meeting Canadian requirements of the day).
Good luck and let us know what you find from the above for next steps
"Cool Prius!"
- Nobody
Old 06-15-2025, 08:25 AM   #3
Thank you SO MUCH for putting this together! I really appreciate it!
Old 06-15-2025, 02:33 PM   #4
Not familiar with these later model boxsters, but BMWs way before that time flash the fog light in case the turn signal light is malfunctioning. For these it is a 'back-up' indicator.
Marc_986 is offline   Reply With Quote
