Old 03-05-2025, 12:55 AM   #1
DME & Fuel Pump relays
HI there having a major issue with the 986 2003 2.7 Boxster
had a slight stutter when accelerating hard and was advised to change plugs and coils
Got the car up in the air wheels off and replaced the coils and spark plug used like for like replacements all part numbers the same Beru coils and Bosch spark plugs it was very fiddley but managed to get them changed. Al torqued up and done one cylinder at a time so no chance of getting the connectors wrong
the battery was off being charged, replaced the battery and the engine turns over at a good speed but does not fire up.
I have checked all the fuses in the foot well nothing blown, before i get her back up in the air and start rechecking my work i have been told it might be worth checking the DME relay and the fuel pump relay
i can see these (Just) above the fuses a set of relays but not sure which one is which or if these can be local part shop replacements or if i need to order from Porsche?
Ohrammer is offline   Reply With Quote
