Old 04-25-2025, 09:56 AM   #1
Just an opinion, but I think that trying to do it without removing the alternator or intake will take longer and lead to more frustration. With the alternator out of the way it's fairly easy.
i just still get nightmares since i had to remove that pulley that attaches using the right bolt that attaches through the alternator, so was trying to avoid that
i did manage to do it from above the engine using these angled pliers
https://www.harborfreight.com/11-in-45-bent-nose-long-reach-pliers-64088.html
i pulled out the U shaped rubber piece from the changeover valve using the pliers
and replaced it with 4mm silicon hose
i always have a spray bottle of rubbing alcohol in my car
sprayed a little on the tip of the rubber hose, so it just slipped onto the nipple of the changeover valve.
worked perfect and no more check engine light
kmarei is offline   Reply With Quote
