Old 02-11-2025, 11:01 AM   #1
Car beeps when locking by Key fob
I have read that this indicates a senor failure;
Doors
Frunk
Trunk
Cubby between seats.
How can I figure out which one if any?
BTW, the board under the seat was sent to Specialized ECU repair, any thoughts there?
Thanks,
DCM
Luckyman01 is offline   Reply With Quote
Old 02-11-2025, 11:38 AM   #2
Scan the car with a Porsche specific scan tool, the last 10 alarm faults are stored in the system.
Old 02-11-2025, 01:44 PM   #3
Well frunk/trunk would have a light on the dash if theyre open or thought to be. Either door would probably cause issues with the windows not raising all the way. I don't think top down would cause a beep since you can lock your car with the top down, so probably the cubby.
alexc0814 is online now   Reply With Quote
Old 02-12-2025, 06:45 AM   #4
Is this car you new to you ? or did the problem recently start ? the switch for the centre cubby is often disconnected intentionally . This provides the beep .. feedback to the owner that the car is indeed locked.
theiceman is offline   Reply With Quote
Old 02-12-2025, 04:51 PM   #5
why anyone would do this idk. nothing i personally hate more than the car beeping at me, although maybe thats from the trauma i endured on the unlock-double beep for a broken door handle mechanism
Old 02-12-2025, 09:34 AM   #6
I believe a single beep is that something is open and a double beep is that there is a fault.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 02-13-2025, 11:51 AM   #7
Feed back on questions
I have owned the car since May of 2004.
I think that the beeping stated when Specialized ECU repair proved me with a new immobilizer board (under the seat) I send them the ECU, immobilizer board and keys. This was many years ago. They told me the beep was normal?
The car does lock all doors and Trunk frunk.
My Acton scanner does not seem to be able to tell me anything.
Except for this issue, she is a no stories car with a lot of prior receipts.
I have no clue as to whether the alarm works.
This is the only thing that bugs me and I have time to figure it out.
Thanks David
Old 02-13-2025, 11:59 AM   #8
Does it beep once or twice?
'98 Boxster 986
Old 02-13-2025, 12:37 PM   #9
That's because your scanner is a cheap "global" OBD II scanner, and not Porsche specific.........
