Old 01-24-2025, 01:08 AM   #1
Oil filler hose replacement
Hi folks,
I'm neck-deep into doing preventative maintenance on my '99 Boxster with 102k miles. It was running perfectly before I attacked it. So, it's got a new IMS bearing and RMS. While the transmission is out everyone says to replace the coolant reservoir tank in the trunk, so I did that today. It went smoothly enough, but I actually got stopped in my tracks at almost the last step.
I simply cannot press the oil fill tube, the one with the accordian kink in it, back on to its mate that goes under the plenum. I pushed as hard as I possibly could, and that oil fill tube hose will not go home. I pushed so hard I cracked its mate that attaches to the top of the engine, so now I get to pull the plenum between the intake manifolds. It was extremely hard to pull off, and I'm finding it impossible to push back on. Clearly I am missing something, but I cannot figure it out. See attached pic. Seems to be lined up ok, but I'm out of ideas.
Thanks in advance,
Steve in LA
alfasteve is offline   Reply With Quote
Old 01-24-2025, 09:16 PM   #2
elgyqc's Avatar
Originally Posted by alfasteve View Post
Hi folks,
Thanks in advance,
Steve in LA
Old plastic loses its flexibility. I stick the end in a bucket of hot water for awhile, or use the heat gun to make it a bit more malleable. My nemesis is the intake tube from the filter housing to the engine, always a PITA to reconnect.
Grant
Old 01-24-2025, 09:30 PM   #3
That's a great idea, thank you! I got it back on, it was just a matter of getting more leverage. Sometimes it's a good idea to just step away for a while.
I still have to get the new oil fill tube on, the one that bolts to the top of the crankcase. Oh joy.
Thank you,
Steve S.
Old 01-25-2025, 09:54 AM   #4
elgyqc's Avatar
Thank you,
Steve S.
You are welcome. I had to change the tube that bolts to the top of the engine like you. It was broken when I bought the engine from a recycler... they were very messy in removing the engine, several tubes and wires broken or cut. The install was a real PITA even with the engine out of the car, but I did it without removing the intake manifold or plenums.
Grant
