Old 01-22-2025, 03:11 PM   #1
986 Headlight bulb change snafu
Upgrading bulbs on my 200 Boxster S. Watched all the videos. Did the passenger side, NP. Stuck on the drivers side. With 3-5x the force on the wrench, nothing budges, no pop, no movement of the light. Wondering if leaning on the headlight in a certain spot helps it release, maybe lifting slightly on the front edge? Don't want to smash things, by cranking too hard and now I have one side with nice bright light an one side with old original style light. Any ideas?
CactusBob is offline   Reply With Quote
Old 01-22-2025, 11:27 PM   #2
Firstly, I would use a 5mm socket, not the on-board tool. Then I would try to lock the headlight. i.e. press against it (possibly a second person) and mentally turn the locking bar backwards, so clockwise on the left-hand side and anti-clockwise on the right-hand side, seen from the front! Then release, i.e. the other way round. Good luck!
997_986 is offline   Reply With Quote
Old 01-29-2025, 10:49 AM   #3
If it remains stuck you may consider removing the wheel well liner and "helping" the headlight assembly out by pushing on the headlight assembly rear cover.
I am wondering if the mount bracket clamp is full forward and not engaged with the headlight assembly.
May I ask what bulbs you chose for the upgrade?
StephanSloan is offline   Reply With Quote
