Old 12-18-2024, 09:45 AM   #1
Window Regulator Question
I have a '98 Boxster and the driver's side window doesn't drop enough anymore when I open the door. I do hear the motor when I pull the handle. I tried the zip tie trick to tension the wire, but it didn't solve the issue. So I believe I need a new window regulator. I've read a lot of threads here and I believe the general belief is that the various OEM options are hit or miss. They often visually look different (so perhaps not OEM). I'm hoping this is a quick project (e.g. mark where the existing window regulator is to minimize and/or avoid having to adjust the new one). My question is...
  1. Should I simply purchase a genuine Porsche window regulator for around $300'ish
  2. Buy a used from a dismantler for around $90
  3. Other options?
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 12-19-2024, 04:27 AM   #2
Check this thread and maybe he solves your problem es well.
I would go for a used one but stick to original.
997_986 is offline   Reply With Quote
Old 12-19-2024, 07:11 AM   #3
Motorist & Coffee Drinker
78F350's Avatar
The genuine Porsche part is best, but I also recommend the URO Parts window regulator as a good aftermarket replacement. I keep a couple used ones around for 'emergency' use, but you are best off buying new rather than one that may have been in service for 20+ years.
Old 12-19-2024, 01:35 PM   #4
I bought a less expensive regulator to fix the same problem. I spent all day trying to get the window to line up and finally gave up, took it out, put the old one back-with a zip tie. Its been working fine ever since, at least a couple of years.
You might want to troubleshoot why the zip tie fix did not work for you. Was it not tight enough? Did it not take up enough slack in the cable?
Wret is offline   Reply With Quote
