Old 12-13-2024, 02:30 PM   #1
Transmision fluid again
I know this has been covered ad-nauseum.
I purchased my 6-speed 2001 S w/ 95,000 miles in July. Not seeing a transmission fluid replacement in the service history, I decided to do it myself. I used the Porsche classic transmission fluid that Pelican sells. 3 cans until it dribbled out of the fill hole.
The fluid that came out was very clean, so I suspect that the previous owner had done the service themselves recently. Since I replaced the fluid, shifting has become significantly worse. The 986 hard 1st and 2nd gear engagement is present now where it previously was not. All gears take more force than previously and the engagement is notchy.
So, did I choose the wrong genuine Porsche transmission fluid?
los36 is offline   Reply With Quote
Old 12-13-2024, 05:51 PM   #2
"50 Years of 550 Spyder"
10/10ths's Avatar
Well….
….ask Pelican if what you bought is correct for your car. They are solid folks and will help you.
Old 12-16-2024, 06:38 AM   #3
I think that I found my answer after some more research. Even though the oil is recommended for the Boxster, it is a GL5 fluid. Not sure if the description is from Porsche or was written by Pelican, but the recommendation may be incorrect. I've read in other threads that our cars require either the other Porsche genuine fluid or a GL4 fluid.
Porsche Classic Gearbox oil (PCG-043-210-52-OEM) DON'T USE THIS:
The correct transmission fluid (000-043-305-49-OEM) USE THIS:
Old 12-16-2024, 01:25 PM   #4
I think you have a different problem with your box than GL4/GL5. I use a fully synthetic GL4/GL5 gearbox oil and also follow the specification, but the differences would never be immideately as significant as you describe, only in the long term. Your box has a problem imho.
Old 12-16-2024, 01:36 PM   #5
No, he is correct, these gear boxes are extremely sensitive to lubricants.
Old 12-21-2024, 09:21 PM   #6
LoneWolfGal's Avatar
How do you like all the hoops Porsche makes you jump through in order to gain access to the transmission? And their requiring a triple-spline bit for the fill plug? It's almost as if they were trying to discourage DIYers.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
Old 12-22-2024, 05:21 AM   #7
piper6909's Avatar
Sadly, most manufacturers play the same trick. A lot of newer cars don't even have a dipstick for the automatic transmission. It's "dealer serviceable only." Luckily, in most cases there's a hack.
2010 Subaru Forester
Old 12-22-2024, 05:29 AM   #8
Registered Member
It does seem like that. I will note that the sole triple square drive that I have (10mm?) has been used on an 88 Jetta, an 02 Passat and the 03 Boxster. It’s a German thing, I think.
The latest is the torx socket you need to buy to install the latest version of the M96 ignition coils.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
