Old 11-23-2024, 09:45 AM   #1
Window Issue
My passenger window wont budge.
Wont adjust for opening door/closing door, not by interior switch or remote.
I suspect a switch problem or motor.
How involved is this to fix and where to get and how much are parts approx?
Its a 2001 S.
2001 Boxster S in Tucson, Arizona
evomind is offline   Reply With Quote
Old 11-23-2024, 03:09 PM   #2
You need to debug first. I'd start with fuses.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 11-23-2024, 03:12 PM   #3
I didnt think it would be fuses as I expected both windows to work off the same fuse, no?
Old 11-23-2024, 03:21 PM   #4
piper6909's Avatar
Do this test at night and with the door open so the interior lights are on.
Engine off.
Key in Run position.
Push the window down or up button while checking the lights.
If the lights dim slightly, (pay close attention, sometimes it's ever so slightly) it's the window regulator.
If they don't, then it's either the switch or the wiring.
Used OEM parts can be found in the parts section. I've had better luck with used OEM over new aftermarket. Just post a parts wanted message.
2010 Subaru Forester
Old 11-23-2024, 06:18 PM   #5
Engine off.
I did that and the interior lights dont dim and I hear a click come from the passenger side door, I assume the relay.
Old 11-24-2024, 03:53 AM   #6
1998 Boxster Silver/Red
But... did. you. check. the. fuses. ??????
1998 Porsche Boxster
Old 11-24-2024, 05:12 AM   #7
Registered Member
Um. Maybe you would take a look at the list of fuses?I have no idea what the answer is, but making assumptions about basic stuff is generally not a productive decision.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 11-24-2024, 03:16 PM   #8
Alrighty then
Fuses all checked out ok so thats that.
Old 11-25-2024, 03:09 AM   #9
Registered Member
Time to start taking the door apart, then.
Tom Coradeschi
03 Boxster
Old 12-12-2024, 09:42 AM   #10
Turns out its the window motor....
Anyone know where to source one besides the dealer?
Old 12-13-2024, 03:38 AM   #11
Yes. See response #4.
Read responses in their entirety.
Old 12-13-2024, 08:10 AM   #12
I read them in entirety.
You are very assuming, judgmental, and condescending.
Do I need to give you an accounting on the steps I took before posting?
Your response has zero value.
If you dont want to contribute in a positive way you dont have to respond.
I hope you read this in its entirety.
Hugs
