Window Issue
My passenger window wont budge.
Wont adjust for opening door/closing door, not by interior switch or remote. I suspect a switch problem or motor. How involved is this to fix and where to get and how much are parts approx? Its a 2001 S. Thanks |
You need to debug first. I'd start with fuses.
I didnt think it would be fuses as I expected both windows to work off the same fuse, no?
Do this test at night and with the door open so the interior lights are on.
Engine off. Key in Run position. Push the window down or up button while checking the lights. If the lights dim slightly, (pay close attention, sometimes it's ever so slightly) it's the window regulator. If they don't, then it's either the switch or the wiring. Used OEM parts can be found in the parts section. I've had better luck with used OEM over new aftermarket. Just post a parts wanted message. |
Alrighty then
Fuses all checked out ok so thats that. |
Time to start taking the door apart, then.
Turns out its the window motor....
Anyone know where to source one besides the dealer? Thanks |
Read responses in their entirety. :cheers: |
You are very assuming, judgmental, and condescending. Do I need to give you an accounting on the steps I took before posting? Your response has zero value. If you dont want to contribute in a positive way you dont have to respond. I hope you read this in its entirety. Hugs |
| All times are GMT -8. The time now is 01:04 PM. |
