Old 12-16-2006, 06:53 AM   #1
ohioboxster's Avatar
My 02 sensor story
Well, one month wait and one hour later I finished installing my factory Porsche 02 sensors. You will notice no check engine light and its throwing no codes! I had universal 02's installed and the car was throwing codes that they were all bad. Im extremely happy right now!
2002 TT
Old 12-16-2006, 09:41 AM   #2
nice
im stuck w the retarted airbag light
my cardomain/pictures page
Old 12-16-2006, 11:23 AM   #3
Hey Randall knows how to fix the air bag light. I think he says it has something to do with the seat belts.
2002 TT
Old 12-16-2006, 11:30 AM   #4
You can use the Universals if you are sure to make the proper connections. The Universals (as the OEMs) get their Reference Air samples through the wire's Teflon insulation. If you use Crimp type conectors, you can seal off this source of Reference Air and the system will throw a code...
Happy Motoring!... Jim'99
Old 12-16-2006, 11:33 AM   #5
How would you properly connect the wires?
Old 12-16-2006, 11:38 AM   #6
If using Universals, I would eliminate the connector altogether and simply splice the two wires together using some Hi-Temp Shrink Wrap or Tape. This will allow the air to enter the wire sheathing and be used by the sensor. You could also carefully make a few pin holes in the sheathing. Just so long as you don't cutoff the Reference Air supply to the sensor...
Old 12-16-2006, 11:46 AM   #7
I did just that and its weird the car ran great but the computer hated them. The universals looked different too even though they are the same ones everyone else used. All I know is I have no codes and Im so happy there are no idiot lights on the dash.
2002 TT
Old 12-16-2006, 02:07 PM   #8
DJ, the airbag light is usually lit because a seat was removed without disconnecting the battery or one of your receptacles has crapped out on you, which is typical... they always go out. Get a couple of new ones from Sunset and install them one afternoon, then have the airbag light turned off.
No, it won't go off by itself... just in case you ask!
Old 12-16-2006, 03:10 PM   #9
I've installed hundreds of universal O2 sensors with no problems.... maybe you just had a defective one. As for the reference air supply, Bosch states that it gets it sample from the main electrical connector. They also recommend not using anything like dielectic grease as this can block the air from the sensor wire.
I've never heard or read of adding holes at the connection site.... I would think moisture would migrate into the wire and casue corrosion.
wvicary is offline   Reply With Quote
Old 12-16-2006, 04:08 PM   #10
I have four 02's for sale if your interested. I can tell you my cel is off and I dont have any codes now. Have you installed hundreds of 02's on Porsches? If so which ones do you use?
2002 TT
Old 12-16-2006, 04:12 PM   #11
Only installed around 20 on various Porsche models over the years and used only Bosch universal sensors. I have had some problems on older Nissans using universal sensors.
Old 12-17-2006, 07:48 PM   #12
Yes, the hole is in the connector on the Sensor half, but if you crimp on the old connector to the new sensor, you run the risk of cutting off this reference sample supply.
You can quite easily use a pin or awl and carefully put a single hole in each side of the sheathing. The hole will be so small that getting moisture or corrosion won't be a major issue, but it will be sufficient to admit a reference sample for the sensor. I'm not advocating perforating the entire length of the sheathing, I should have made it clearer...
