Old 09-28-2024, 01:34 PM   #1
Rear speaker install confusion
I have a 98 986, door speakers. Bought a rear kit and wiring from Becker. Can anyone tell me where it should plug in? I don't see a spot on my amp or cdr10. I've upgraded to double din but I am not sure if the speakers should come straight from the head unit or pass through amp first as the double din has a built in amp. Help?
chromecarz00 is offline   Reply With Quote
Old 09-29-2024, 05:40 AM   #2
Registered Member
There is nowhere to plug it in. I’d wire it direct to your head unit, assuming it has a free set of outputs.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 09-29-2024, 08:07 AM   #3
KevinH1990's Avatar
I installed a 6-channel HAES amp from a 996 cabriolet. The 996 amp had outputs for the rear speakers. Here's a link to instructions for adding the HAES amp if you decide to use that option: https://www.renntech.org/topic/29250-rear-speaker-wiring-to-a-haes-6-channel-amp/
The advantage of using the HAES amp is that it fits in the space for the amp that was originally installed in our cars. However, I expect other amps or your head unit would provide better sound quality.
My sound system (and audio installation skills) have evolved over the years. If I were starting from scratch today, I would probably install a good 6-channel aftermarket amp in the front trunk and use that to power the speakers.
Adding rear speakers will help the audio in the car, but you may still feel like it is lacking something. I found that upgrading the dash and door speakers made a significant improvement to the sound in the car. I recently added some larger and better quality woofers to the doors. You can read about that here: https://986forum.com/forums/boxster-general-discussions/79558-door-speaker-recommendations.html
KevinH1990 is offline   Reply With Quote
Old 09-29-2024, 09:22 AM   #4
Fantastic thanks guys, will wire straight to HU
Old 09-29-2024, 03:39 PM   #5
My rear speakers were wired to the original head unit. When I upgraded to a Sony double din I ran the rear wires to the frunk and installed a 6x40w cabrio amp. I didn’t notice much difference and it was a hassle. So I think you’ll be fine running them to the head unit.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
