Old 09-06-2024, 02:12 PM   #1
Rob175's Avatar
Dip stick tube loose
Today while checking my 98' Boxster's oil level, with the dip stick located in the rear trunk, I noticed as I was sliding the dipstick all the way back in the tube's end slid in about 1/4". Than made it difficult to push the yellow dipstick in all the way to the little O-ring seal.
My guess is the last oil change "monkey" forced the dip stick in too far after my last oil change (a few months ago)....but that's just a guess.
How does the dip stick tube fasten to the oil/coolant "tray" in the rear trunk? Is there a way to keep the tube from moving when replacing the dip stick (without taking 1/2 the car apart)?
Maybe I should try a plastic epoxy (JB Weld)??
98' Boxster
Rob175 is offline   Reply With Quote
