Old 09-18-2024, 10:39 AM   #1
Originally Posted by theiceman View Post
what plugs are those .? have the exact number ? im looking to replace mine but tough getting recommendations on which ones to use
I also have a 2001 Boxster S . 170K km on it . I am just replacing the variocam pads and updating the tensioners.
mine also had the rear engine skid plate missing and even had a patch on one of the cats so definitely some off road activity.
When i got the new skid plate ( 80.00 used ) i noticed the holes didn't line up on the studs to mount it . Someone on here told me that this was not all that unusual and told me how to fix it ( a ratchet straff and loosen and retighten the crossmember. Obviously this needs to be done before alignment.
Looks like a big job. Not sure when my time will come...
For spark plugs, I used Bosch FGR-6-KQE.
NGK alternative is BKR6EKUB. Beru alternative is FGR-6-KQU. Of course, you can pay 5x more for Porsche genuine plugs (which looks strikingly similar to the NGK which happens to be cheaper than the Bosch).
I will note that I did some light Googling on Bosch vs NGK today. On a BMW forum, there were several stories of Bosch plugs loosening on their own. I can definitely say the Bosch plugs that I removed were very loose. I think I may have gone NGK given what I know now.
los36 is offline   Reply With Quote
Old 09-19-2024, 11:13 AM   #2
excellent info thanks .... strangely enough while doing this job i found the plugs shockingly loose. i think they were Bosch but i will double check.
theiceman is offline   Reply With Quote
Old 09-19-2024, 03:39 PM   #3
If the plugs were loose, is Not because they were Bosch brand..
it was because the person that got them installed didn't torque them down properly..
Old 09-20-2024, 06:10 AM   #4
agreed... just going to retighten for now ... if car warrants it . i will replace plugs and coils down the road..
Old 09-20-2024, 06:07 AM   #5
I also read that new plugs and reused plugs are to be tightened to different values. If eusing plug you tighten to 18.5 foot lbs vs new at 22. , problem is i have read so much recently i cant remember where i saw it .
Can anyone confirm? when i did the valve covers i went to check a plug and it was barely finger tight but looked in great shape so just want to re tighten.
Old 09-20-2024, 09:24 AM   #6
Motorist & Coffee Drinker
78F350's Avatar
Correct.
One of my cars recently had one plug that was squeaking on start up, but otherwise ran fine. When I checked, #2 plug was barely finger tight. I use anti-seize on the plugs and I expect that if the torque is a little low when they are installed, they will loosen over time.
The Factory Manual (updated as of 2004) pg 03--1.6 says 30 Nm/22 Ftlb new and 25 Nm/18.5 Ftlb used.
