Old 09-07-2024, 04:14 AM   #1
Pressure line for power steering
Howdy ,
I'm rebuilding my 986 from an accident and trying find the best solution.
Old power steering line and return is gone and can't be repaired.
I did manage get 2nd hand pressure line and return but after fitting it's looking like it's from RHD car not LHD.
New ones are over the budget hence I need find some way to use one which is looking like it's from RHD.
Cutting earlier and fitting rubber cable would work ( of course it will be done by specialist shop )
Any other ideas?
Wysłane z mojego M2101K9G przy użyciu Tapatalka
joshua3mm is offline   Reply With Quote
Old 09-07-2024, 05:34 AM   #2
elgyqc's Avatar
Post #57 in this thread shows the successful repair I made to the return hose. Hydraulic hose and clamps.
https://986forum.com/forums/boxster-general-discussions/82558-bought-2000-boxster-s-project-3.html
The high pressure line may be more difficult, a hydraulic specialist should be able to help you, either with the fabrication of new lines or repairing/adapting what you have.
Grant
