Old 08-27-2024, 10:39 AM   #1
Headlight Corner Reflector Broke
While pulling my housing out to change a bulb, I accidentally grabbed the corner reflector and broke off the tab that holds the front corner on.
Got back to work and put on some thick 2-part epoxy to attach that point directly to the headlight housing, hopefully it holds. If it falls off, then I'll buy a new one.
Anyone else have ideas on other things that I could do about it? the epoxy will take a few hours to cure so I can still wipe if off (for now).
S50Sinner is online now   Reply With Quote
Old 08-27-2024, 12:27 PM   #2
just speaking for myself but i just went the route of headlights without those pieces, I never saw the reason WHY they would even do that when replacements are so expensive. There are tons of headlight options that are all in one which is what i did. the price you pay for just that little piece is the price you could pay for a whole new headlight on a Dodge Ram. Not worth for me and was well worth just buying a pair that didnt have those to worry about
Hamstuh is online now   Reply With Quote
Old 08-27-2024, 04:23 PM   #3
JBauer's Avatar
You could run a strip of clear PPF along wherevthe edges meed the headlights.
Old 08-27-2024, 08:00 PM   #4
Beelzy's Avatar
I simply used super glue. Stays on even past 100mph.
Beelzy is online now   Reply With Quote
Old 08-28-2024, 06:39 AM   #5
Swapping for headlights without reflectors is an option, Hamstuh, but some folks like the stock look. For the epoxy, S50Sinner, make sure the surface is clean before applying for a strong bond. Super glue (like Beelzy mentioned) can work too, but be careful not to get it on the lens itself. Good luck with the fix.
warner_markk is offline   Reply With Quote
Old 08-28-2024, 10:53 AM   #6
Thanks everyone, it's holding strong so far. I'll make sure to give it a little push with my hands every once in a while, if it pops off under finger pressure I'll try sanding the surface and re-applying the epoxy with more contact points.
I definitely agree that they don't need to be separate pieces, but I like the OEM lights, and plan to restore mine at some point, maybe paint the insides of the housings like particlewave did a decade ago. I'm a big fan of the amber turn signals and old-school reflector housings.
I'll update if/when they fall off.
