Old 08-27-2024, 04:23 PM   #3
JBauer
JBauer's Avatar
Originally Posted by S50Sinner View Post
While pulling my housing out to change a bulb, I accidentally grabbed the corner reflector and broke off the tab that holds the front corner on.
Got back to work and put on some thick 2-part epoxy to attach that point directly to the headlight housing, hopefully it holds. If it falls off, then I'll buy a new one.
Anyone else have ideas on other things that I could do about it? the epoxy will take a few hours to cure so I can still wipe if off (for now).
You could run a strip of clear PPF along wherevthe edges meed the headlights.
