Old 08-12-2024, 05:39 AM   #1
2000 986 & 1972 914
martinef1963's Avatar
Convertible Top
hello,
2000 Boxster, base model, 2.7L engine, triptonic. I just had the convertible top replaced with an upgraded window type from the plastic.
The convertible top opens halfway and that is it. I can close it, the clamshell opens and closes fully, but the process stops when the convertible top reaches the halfway point.
No weird noises from the convertible top motor or clicking or grinding noises from the convertible top transmission (L/R). It just stops mid-way.
Any suggestions on where to start?
As usual, thanks for all the comments & help.
martinef1963 is offline   Reply With Quote
Old 08-12-2024, 09:38 AM   #2
Motorist & Coffee Drinker
78F350's Avatar
Are the mechanism arms installed correctly? Is #9 in the diagram generally oriented like an "A" vs like a "V"?
Old 08-12-2024, 05:53 PM   #3
78F350 nailed it - I believe that is the behavior if you install these upside down.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 08-13-2024, 01:11 PM   #4
2000 986 & 1972 914
thanks, I will look at it to make sure the boomerang is in the A position.
