Old 07-24-2024, 09:25 AM   #1
Originally Posted by alexc0814 View Post
Don't get the cheap ones from amazon. I have 20mm all around, and when I went to motorsport hardware to get wheel studs installed, Cecil noticed that my spacers were lipped, and only the very edge of the lip was contacting the hub, so I just got some new spacers from him there while I was there.
I'm on 18 inch turbo twists, and 20mm all around is no problem. Almost wish I went a little more in the front for appearance, but this looks good.
Also- based on my research at the time, the only appropriate wheel bolts were $2-300 for a set. That's why I had studs installed, since it actually ended up being a little cheaper with both parts and labor vs parts alone for new wheel bolts.
Are you lowered also or stock ride height? I'm looking at 15Frt/20Rr but would go 20/20 based on your testing. No fender rubbing I'm assuming.
Fishbone is offline   Reply With Quote
Old 07-24-2024, 02:15 PM   #2
Lowered on H&R springs. I think there's maybe very slight rubbing at full lock, but my car usually stalls at full lock with the ac on anyway lol
edit: sounds like you could just swap out your back spacers onto your front wheels to test it out if you had any doubts, though
alexc0814 is online now   Reply With Quote
Tags
boxster s , rims , spacers , wheels
