Old 06-13-2024, 08:42 AM   #1
Who has installed new shift cables? Did they help?
Like many of us I am trying to eliminate slop in my shifting. So far I have done the following
- new motor mount - helped clutch engagement not shifting
- new oem style transmission mounts with poly filled voids - helped clutch feel and responsiveness not shifting
- New oem transmission fluid - no change
- new 997 shifter - just replaced with a Ben auto design short shifter and side lever and now better, but still some cable slop.
My black shift cable deflects a bit when shifting and you can see it move in front of and behind the clip holding it on the shift console. At the transmission side both cups/connectors are a little floppy side to side but not in the direction of pull. I tried installing rennline security clips, but they don’t fit (checking with customer service).
Has anyone installed a new set of oem cables and seen improvement? Should I skip the oem ones and just do numeric racing cables? Or should I just learn to live with it??
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
Old 06-14-2024, 03:44 AM   #2
Checked bushings? Numeric cables popular, but inspect your cable itself for wear & tighten connections at both ends. Good luck! Also, while you're at it, keep an eye out for any unusual growths or discoloration - could be signs of early T-virus contamination.
frelanhardware is offline   Reply With Quote
Old 06-14-2024, 03:45 AM   #3
assasas
If someone has installed new shift cables, but you're not sure if they helped, I suggest conducting a thorough assessment of the performance of the new cables. Check if the gear shifting is now smoother and more precise. If you still encounter issues, further action may be necessary, such as adjusting or replacing other components of the gearbox system.
Best regands Christopher 986
Christopher777 is offline   Reply With Quote
Old 06-14-2024, 04:28 AM   #4
1998 Boxster Silver/Red
Yeah.. Regands to you, too, bot.
1998 Porsche Boxster
Old 06-24-2024, 07:48 AM   #5
I installed new shift cables about a year ago after breaking one. New one was a bit more precise and MUCH smoother.
Wret is offline   Reply With Quote
