Old 05-08-2024, 05:14 PM   #1
Ignition/Steering Lock Issue
I have a '98 Boxster with 78,000 miles.
Recently the igntion key receiver-barrel assembly has started acting up.
When I turn off the car, remove the key, and open the door the idiot lights stay on and the key-door alert beeps and the steering wheel does not lock.
I have to insert, turn and remove the key several times and otherwise jiggle it to get that steering wheel lock to "click" and the lights/beeping to go off.
So one question: is the steering lock mechanical only or electromechanical, ie., is there a solenoid in the receiver-barrel that engages the steering lock?
I also note that I recall there being one of those protective metal "doors" that keeps debris out of the barrel body when the key is removed, but if there is such a door, it isn't closing any more.
I sprayed some silicon lube into the body-barrel, but it didn't seem to help.
Any thoughts as to how I can get the key receiver to work properly again?
austinporsche is offline   Reply With Quote
