Old 04-01-2024, 10:07 AM   #1
Tiptronic malfunction
2004 2 7 Boxster. .Wasnt ran for 2 + years. Battery tender failed to keep voltage up. Battery replaced. Once around block, everything ok. Week later took out and check engine light on as well as Tiptronic dash indictator flashing 4 and D alternately. Shifts through 4th gear, doesn't seem to go into 5th. Other then the lack of 5th gear, seems to run ok.
Any ideas?
Mcod is offline   Reply With Quote
Old 04-01-2024, 02:34 PM   #2
Get the codes read by a shop that has a PIWIS, PST2 or Durametric diagnostic. Dash messages are nice but codes are definitive. And because the car is a TIP, you need Porsche specific capability in the diagnosis tool.
Where in FL is the car?
Prior '70 914, '99 986 Boxster, '01 Boxster S
