Old 11-26-2023, 08:11 PM   #1
Oil Change WO removing drain plug
Hello,
Is it possible to change the oil without removing drain plug?
I understand some Porsche models one can suck out the oil from above and refill.
Is this possible with Boxster 2000 vintage?
racerjack is offline   Reply With Quote
Old 11-27-2023, 05:24 AM   #2
I have thought about it but the oil fill and dipstick tubes have quite tight bends which most oil extractors wouldn't be able to make.
You can try but most like it isn't possible.
Makrilli is online now   Reply With Quote
Old 11-27-2023, 06:14 AM   #3
You might be surprised how many of these cars we get flat bedded in because they tried to do this and found out that the "extractors" get stuck on the sharp bends and baffles in the oil sump, requiring us to remove the sump cover and get them out.
Simply a very bad idea.......................
Old 11-27-2023, 08:40 AM   #4
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by racerjack View Post
Hello,
Oils changes are easy on a 986. Why would you not want to do it the normal way?
Old 11-27-2023, 11:06 AM   #5
Oh and by the way you have to get under the car anyway to change fhe oil filter, so vacuuming the oil doesn't really save you any trouble compared to draining.
Old 12-01-2023, 10:35 PM   #6
I do the suction method oil change on my other cars, but with all the history of the Boxster engine I want to be able to get a better look at the oil. Can't do that thoroughly enough without looking at the magnet on the drain plug... if you don't have a magnetic drain plug, you ought to get one.
Even if I have to get under a car to get at the filter, I find the suction method less likely to result in cleaning up spills- I know, it's possible to do it the regular way without spilling, but it just doesn't seem to happen that way.
Hasdrubal is offline   Reply With Quote
Old 12-02-2023, 04:25 PM   #7
Drain plug and filter housing both remove perpendicular (straight down) to ground and thus minimizing any "mess". Contrast w my F150 3.5L TT EgoBoost which is a serious drain plug "squirter" and major filter dribbler (onto fixed undercarriage panel ) as both remove parallel to ground.
Regardless, for draining and even filling fluids in vehicles and other equipment these flex/shapable shields/funnels are great to have on hand.
https://www.amazon.com/gp/product/B08TTGTYR2
Good luck
"Cool Prius!"
- Nobody
Old 12-04-2023, 11:36 PM   #8
Just remove the plug and change your oil like a normal person.
Weirdo...
Old 12-05-2023, 06:30 AM   #9
1998 Boxster Silver/Red
Weirdo...
It appears my late night match has been revealed...
Good to see you here. Again.
1998 Porsche Boxster
Old 12-08-2023, 02:13 PM   #10
lkchris's Avatar
Hello,
Not.
Note that the cars that facilitate this also have their oil filter mounted on the top of the engine, meaning there is no need to get underneath for an oil change.
The fact the 986 filter is underneath is then a clue.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
