Old 11-28-2023, 09:55 AM   #1
lkchris's Avatar
Porsche Classic Gear Oil
Is this stuff magic enough for the Base 5-speed?
It creates doubts when they don't distinguish between Base 5-speed and S 6-speed.
Mentioned in passing it was time for gear oil change on my '01 Base to mechanic doing a new motor mount and when I returned he had done the oil change, too. Of course it almost won't shift at all in cold weather before warmup and I need to get something better in there.
Is there a source for DIY quantity of the right stuff or do I need to see dealer?
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 11-28-2023, 10:48 AM   #2
Royal Purple
That's what I used.
DCM
Luckyman01 is offline   Reply With Quote
Old 11-28-2023, 10:55 AM   #3
What you should be using:
Old 11-30-2023, 12:14 AM   #4
Multi-Boxer Driver
Deserion's Avatar
I’m using what JFP recommends.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 11-30-2023, 09:55 AM   #5
lkchris's Avatar
I will also
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
Old 01-31-2024, 10:36 AM   #6
lkchris's Avatar
Got the bad stuff out and good stuff in yesterday.
Shifting now great.
Thanks for the discussion and advice. Thanks also to Sunset Porsche.
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
Old 01-31-2024, 12:08 PM   #7
Shifting now great.
Funny thing that.......................
Old 01-31-2024, 05:51 PM   #8
Multi-Boxer Driver
Deserion's Avatar
Here's the weird thing for me. I used the 000-043-305-49 Porsche fluid on a recent change, now the transmission is more reluctant to easily shift when it's cold (ambient) or not warmed up. Admittedly I cannot recall if it exhibited the same with low ambient temperatures before, maybe it did much to my empty recollection. During the other weekend's HPDE in Savannah it was 25 in the mornings and it was rather hesitant to shift.
Once the engine/trans warm up it's good to go. I did follow the Bentley manual on the filling procedure to avoid overfill.
-Chris
Old 02-07-2024, 09:32 PM   #9
I would use the Mobil 1 Synthetic GL-5 oil. I’m sure the Porsche branded oil is good too but probably not any better than the cheaper Mobil stuff.
Bush Pilot is offline   Reply With Quote
