Old 10-03-2023, 12:14 PM   #1
highsider's Avatar
PCM 1.0 Blank Screen Repair
I have a retro fitted PCM 1 fitted to a 1998 Boxster. This was fine for a while, but recently the display has gone blank even through the radio still works - so it still functions. I have disconnected the battery, and turned it back on again - but it remains blank. The backlight is on, so I assume this is either the LCD or a display component?
Has anyone had something similar and has been able to rectify it?
highsider is offline   Reply With Quote
Old 10-04-2023, 06:45 AM   #2
BruceH's Avatar
No idea if it can be fixed but I just installed a HU from AliExpresswith Android and CarPlay. I love it. You can read my review on the linked page:
https://www.aliexpress.us/item/3256805560176127.html?spm=a2g0o.order_detail.order _detail_item.3.3638f19c2S3VEW&gatewayAdapt=glo2usa
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 10-08-2023, 02:03 PM   #3
highsider's Avatar
Thanks. That is a great option!
Quick couple of questions;
- what made you go for the specific "Color: 7862 256G Carplay LT" model?
- the wiring photo didn't look that plug and play. Were there extra changes needed?
- Did the anti tamper sensor still work okay?
Old 10-09-2023, 07:00 AM   #4
BruceH's Avatar
I am not sure why they list a color, China, lost in translation maybe? It only comes in one color. I got the 8gb/256gb version. It wasn’t that much more and I always figure you can never have too much memory.
I have a stock wiring harness, no changes were needed. I did have to modify the surround with a dremel which was easy to do.
No issues with that, but I was replacing another non OEM single DIN HU. I do not think there would be a problem.
After several weeks of driving with this unit, I am still very pleased with the functionality and quality of the unit.
DEPO Tail Lights
Old 10-10-2023, 01:48 PM   #5
highsider's Avatar
Thanks Bruce.
I'm getting the PCM1 unit assessed for repair. If it doesn't make financial sense, then I'll be picking one of these up.
Old 10-10-2023, 02:00 PM   #6
BruceH's Avatar
You are welcome!
DEPO Tail Lights
