Old 08-08-2023, 05:05 AM   #1
pilut2's Avatar
Front end rattle solved
I lifted the car this past weekend to try to diagnose an intermittent front end rattle. After prying and shaking everything visible I discovered that the plastic brake cooling air deflectors attached to the lower control arms were loose. They were clipped on properly but had a fair bit of play in them. I drilled a couple of small holes in them and zip tied around the lower control arms.
No more rattle!
1999 Boxster, Ocean Blue Metallic-grey top.
LN IMS dual row-, Ben's short shift kit
pilut2 is offline   Reply With Quote
