Old 11-28-2006, 06:28 PM   #5
I decided the best place for the GPS was on the steering column between the wheel and the cluster, it blocks off the digital display but that's no hardship, it is mucj, much easier to look at there. To hold it steady I cheated a little, when I did my 4 stalk upgrade I stuck two neodynium magnets on the inside of the column cover, I then got a right angle piece of clear acrylic with two matching magnets which I attached to the GPS (a Dell Axim PPC). It now "snaps" in to palce and holds real right then when I remove it there isn't so much as a trace.
Chris.
http://www.lawlai.com/sig.jpg
ukchris is offline   Reply With Quote
