Old 03-18-2023, 10:42 AM   #1
Removing top and frame
Hello everyone, I’ve been trying to remove the top and frame off of my boxster, like seen in this tutorial
https://sites.google.com/site/mikefocke2/removingthetopandframe
But after removing the 3 13mm bolts on each side, removing the sensor, and the 2 Philips screws next to the 13mm bolts, the roof still won’t budge. I’ve looked all over the forums, and none of the solutions work. Any idea if there’s maybe a bolt or torx screw or something that I missed? I cant submit photos because I’m on mobile, but I’ll try to submit soon. Thank you
DaveRad is offline   Reply With Quote
Old 03-18-2023, 10:46 AM   #2
Images of the 3 bolts removed along with the sensor
Old 03-18-2023, 11:46 AM   #3
elgyqc's Avatar
I did this 4 times last year... as I remember it the instructions you refer to should be OK. Possibly the bracket is stuck in place by oxidation and needs some penetrating oil and/or gentle encouragement with a rubber mallet or pry bar. Just be very careful to not damage the foam liner.
Grant
Old 03-18-2023, 12:37 PM   #4
Motorist & Coffee Drinker
78F350's Avatar
You said Phillips screws removed. Confirm these:
Old 03-20-2023, 02:44 AM   #5
Hi friend
Thanks for the explanation with the pictures, my brother was trying to do it for a long time.
Leenaa is offline   Reply With Quote
Old 03-20-2023, 02:45 AM   #6
Hi friend
Thanks for the explanation with the pictures, my brother was trying to do it for a long time. .
